Drivers side rear door says its open.
2002 JEEP GRAND CHEROKEE
4.0L
MARK21
The left rear door says its open when its not, I've checked the wires from plug to plug w an Ohm gauge. No broken wires were found. Even tried adjusting the door striker with zero luck. Any help would be appreciated!
Dec 9, 2015 at 9:37 PM
CARADIODOC
  • 34,306 POSTS
The switch is built into the lock / latch assembly. Unplug the four-pin connector from it. If the light goes out, replace the assembly.
Dec 9, 2015 at 9:59 PM
MARK21
The light did not go out. I already had that plug off that's how I tested the wires. From that plug to the plug at the door hinge side
Dec 9, 2015 at 10:45 PM
CARADIODOC
  • 34,306 POSTS
In that wiring harness, ground the terminal for the tan / yellow wire. I can't tell from the wiring diagram whether that switch opens or closes when the latch is closed. The only way to know for sure is to take the right door apart and make a comparison. Instead, if grounding that wire makes the light turn off, suspect the latch. If there's no change, that wire could be grounded to the body, or it could be broken between the door hinges. You said you checked it for continuity, but also check it for being shorted to ground.
Dec 9, 2015 at 11:03 PM
