No mode control. Cannot change air flow direction to the defrost position. All other functions and controls seem to work. Hearing a constant repetitive squeak coming from under the dash on the drivers side. Suspect the main drive gear in the mode door actuator has broken loose and continues to receive a drive signal to find it's home position but it can't, so it is told to continue rotating until it finds a good reference point during the self calibration. I need to know the easiest and least damaging way to remove and replace the mode door actuator. Any guidance or information would be sincerely appreciated. Thanks.
Sep 9, 2025 at 3:28 PM
