Here's the scoop: daughter A backed her vehicle into daughter B's G6 (the car in question), caving-in the driver side front door. Easy enough, I'll just get a door and swap it out.
I did that. with the panel off, I tested the lock, and tested the handles (inside and outside), and everything functioned as expected. I was quite pleased. I closed and opened the door numerous times and it worked just fine. buttoned up the door panel and was good to go.
The first time she drove it, she couldn't get out of it. it just wont open from in or out. Removed the torx on the inner handle to get at the cable to test it, it has resistance so it's connected. outside handle 'feels' the way I would expect it to.
Suggestions at this point? At wits end. Thank you in advance.
Jun 10, 2019 at 1:13 PM
