Drivers side front door panel speaker not working
2009 HOLDEN BARINA
71,000 MILES
CUR
I noticed today that the speaker on the drivers side front door (down around where your calf is) isn't working. I've only bought this car about 3 months back 2nd hand from the dealership, im unsure if it was ever working >.<
Wondering how to gain access to the wiring behind it (removing the panel? and how to put that panel back in..) so I can first check to see if it's just a cable that has come lose, or if the speaker itself is dead - replace it myself with another of the same type bought cheaply rather than being charged out the nose at the dealership for it's repair.
Oct 7, 2013 at 6:14 AM
MHPAUTOS
  • 31,937 POSTS
You will have to locate all the screw attach points, some may be hidden under plugs, and the trim will also be clipped with body trim clips, I have not taken one of these off before, but like most trims, you just have to take care and feel for tight spots this is where attach points are, a local mechanic would take about 15Min to pull the trim and you could do the rest.
Oct 12, 2013 at 4:35 PM
