Drivers side door handle replacement
2012 RENAULT MASTERS
30,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
GOATFACE
Driver's side door handle is broken. How do I fit a replacement handle? The vehicle has central locking, so there is no key barrel on the driver's side.
Thanks for your help.
Jan 23, 2020 at 1:55 AM
Unfortunately we don't have a manual for this vehicle as it is not offered in the USA so we cannot get the actual procedure. However, this is no different then most vans like the Masters. You need to remove the inner door panel and you will see to bolts on the inside that when you remove them, the handle will come off from the outside of the vehicle. Then you simply connect the new one and put the bolts on.
Jan 23, 2020 at 4:23 PM
