Okay, it sounds like the left (driver side) temperature control switch might be at fault. Unfortunately, the control face communicates any changes to the HVAC control module via a Network Serial Data bus. So, it's not something we can even pull the front control unit out and test to see if it's sending the correct voltage like the older systems. This would be a data packet the front controls send to the control module that is buried in the dash. Also, I think I read another technician mentioning it was a 6 hour job to replace one of the temperature sensors, but I don't think that is the issue, it sounds like the temperature knob is not sending the correct voltage signal inside to the front unit until it gets to a certain point and then it sends a full voltage signal.
Do you hear any type of door noises with the blower on low and changing the temperature on the driver's side? If it were the door sticking, you would most likely hear it make its fully swing after unsticking.
I see some type of Auto Switch or Sync Switch; I assume that will change both sides to the same temperature. Can you see if that changes them equally?
If you want to try getting at the lower temperature sensor, here's where it is, the only issue is if there's an Airbag there, do not disconnect it. You can see in the first diagram, circled in green is your gas pedal and the lower temperature sensor is above it, the second diagram is taking out that small section of the dash below the steering column. And the third diagram is a possible Airbag that might be there. Depending on the model but see if you can take look up there for access to anything, the door actuator is up there as well. I'm not sure you'll be able to get to it, but it's worth taking a look.
The fourth diagram shows the driver's side knee airbag which is what would be there. Thats something you don't want to mess with, they can go off very easily if the connector happens to receive even static electricity, since they are set off by very low current flow.
I honestly don't know why everything seems to be so tight on this vehicle and difficult to get to, I'm going through all the wiring diagrams, looking for a way to test either the control unit or the door actuator. But things are tough on newer vehicles without scan tools that have special functions.
Oct 12, 2022 at 12:19 PM
