driver's seat does not move back
1986 CADILLAC ELDORADO
70,000 MILES
BLONDIE1015
The driver's side power seat is too close the dashboard, and we cannot move it back. The power buttons move the seat up and tilt, just not away from the dashboard! What might need to be replaced?
also- is there a do-it-yourself way to repair a headliner?
Jul 1, 2013 at 11:42 AM
JDL
  • 16,098 POSTS
I don't have a wiring diagram for your power seats, so I can't walk you through it. You may need to remove seat from vehicle so you can get at the motor/s under neath. If two or three motors under the seat, you could figure which motor does what by using jumper wires for voltage and ground with inline fuse. The motors are reversing so you may need to reverse jumpers. If one motor won't do anything with the jumpers then the motor is probably bad.
If the passenger side seat motor works ok, you might be to put it on the driver side? Also, with the seat out you might be able to manually set the seat where you need it, then re-install seat.
Anything to do with switches or wiring problem, I can't track it without wiring diagram.
Jul 1, 2013 at 2:26 PM
