The driver’s window will not go up sometimes! The previous owner replaced the switch motor and module in the door! I have a scan tool and can see when using the switch to go you can see it’s sending the command but will not go up! You can also hear the module in door click! I’m suspecting it has a wiring problem in the door or on the floor to module under the seat but can’t find a wiring diagram! Could you please help! Thanks
Nov 27, 2022 at 10:16 PM
