Every other window works fine. There is no power to the connector plug. I ran a hot wire to the regulator to make sure that is not the issue, it works just fine. Also passenger front door window only works from the switch on the driver's door. Not too sure where to go from here minus rerouting wires all the way through the door. Any advice or positive/helpful input is appreciated!!
May 20, 2020 at 9:18 PM
