Shortly after programming a new key fob the drivers master door control only can raise and open the drives side window.
At each door i can control the window like the front passengers, rear left,
rear right at the control at each door with its window. As for the tailgate window, it will work only with the key in the tailgate door.
So.
1) at the main driver's door all window functions are gone except for drivers' window.
2) I cannot also control the tailgate window at the switch found on the "dashboard".
3) Also, the main drivers side control for locking all doors does not respond.
What I did:
I went through each fuse in the car. The interior fuse box, and engine compartment fuse boxes to look for visual signs of being blown. Nothing.
I took off the main controller found in the driver's side door. Took it apart looking to clean any contacts. I did. Nothing.
I thought I could find a relay for all of these, but nothing was found. Nothing.
Could I have messed everything up? Meaning all the codes by getting the new key fob working?
Anything you could provide would be helpful?
Al
So.
What I did:
Al
Feb 3, 2022 at 8:04 PM
