The driver's side window does not work?
2001 CHEVROLET TAHOE
323,564 MILES • 5.3L • V8 • 4WD • AUTOMATIC
TIMWENDLING1994
Okay, so my vehicle listed above z71, all the windows work except driver side. I have power on the brown wire while pushing switch, but nothing on the dark blue wire. I can switch the wires by unpinning them from the connector and the window will roll down. I can unpin them again swap sides and it will roll up brand new switch and window motor and regulator window is not binding does the same thing if I take motor and regulator assembly out of the door and just leave it hooked up. I'm lost.
Sep 8, 2023 at 8:50 PM
It sounds like you have a bad ground G200 (upper left kick panel) the black wire coming out of the main window switch. I would work the switch and if the black wire lights up the ground is bad, here is a guide to help and I have included the window wiring diagrams so you can see how the system works:
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Sep 9, 2023 at 1:21 PM
TIMWENDLING1994
Well, ground was fine tested it with another switch and it works got a faulty switch from parts store.
Sep 9, 2023 at 8:35 PM
It happens, glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Sep 11, 2023 at 11:20 AM
