I took the car to a mechanic and he determined that the brake pads and the rotor needed replaced. While we made this repair, we discovered that the brake caliper was stuck. So, we finally got it unstuck by disconnecting the brake fluid tube to allow air to escape. This temporarily fixed the problem, however the bad smell came again from the same tire and it was very overheated. So, we went to the junkyard and took a brake caliper off the same vehicle. This did not fix the problem either. This caliper also got stuck. So, I decided to stop being stingy and I bought a brand new caliper. It's been installed for about two weeks now and I have been driving regularly, and the smell and overheating has come back again. I don't know what the problem could be and it is becoming very frustrating. It's obvious that the smell and overheating is coming from only the driver side tire. The other tires don't smell or overheat like the driver side one does. Any insight would be greatly appreciated.
May 19, 2020 at 12:59 PM
