After removing lugs nuts driver side tire will not come off
1991 DODGE SHADOW
60,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
TREMAYNE JONES
MEMBER
1 POST
FOLLOW
I'm changing the brake pads on the car and I took all lugs nuts off and the tire won't come off. what should I do?
Dec 30, 2018 at 5:46 PM
DANNY L
CERTIFIED EXPERT
Hello, I am Danny.
Sometimes it's just a real tight fit. Usually wearing a sturdy shoe I would kick the tire at the 12 , 3 , 6 , and 9 o'clock positions until it comes loose. Here is a tire removal tutorial in case it helps:
Keep us updated! Hope this helps and thanks for using 2CarPros.
Danny-
Dec 30, 2018 at 6:02 PM
STEVE W.
CERTIFIED EXPERT
Yep, rust or corrosion can make it seem like the rims or brake parts are welded in place. A good hard kick or two can break the tires loose. As for the brake rotor/drum those can really be a bear to get off if they are rusted in place.
