driver side rear tire and possible dc joint
2005 MERCURY MOUNTAINEER
89,000 MILES • 4.8L • V8 • AUTOMATIC
LOVER45
I recently changed both rear brakes and rotors..after doing this during rest drive passenger side was making grinding noise ..so after I jacked car up again I went to remove wheel and that is when I noticed that the wheel wiggled in and out ...I think the problem stems from a part that is connected to the hub it is covered by a accordion looking rubber boot the whole assembly moves up and down which does not happen on other side piece also has part of anti lock brake system attached to it is this a cv joint I am worried cause I know it needs replacement but I am unsure what this part is ...could it be a axle shaft, cv joint joint,,,I am unsure could you please help me identify this part....THANK YOU
Apr 3, 2015 at 12:13 PM
SATURNTECH9
  • 30,869 POSTS
The part that the cv axle end goes thru and the abs speed sensor is hooked to would be the hub assembly.I dont know why after a break job it would be suddenly loose?What did you take off when you did the rear brakes?
Apr 3, 2015 at 12:34 PM
