I would suggest first checking that the left headlight fuse is intact, see image 1.
If in order, next check that you have 12V at pin 7 of the headlight connector, see image 2.
This can be done using a test light or voltmeter.
Also, check that the black ground cable at pin 6 has a good ground connection. Use the test light or voltmeter and check that you have the same result as using a good chassis ground.
How to:
and
and
Does the HID light up if you supply your own 12V at pin 7?
Hope this helps.
Cheers, Boris
Aug 24, 2022 at 8:14 AM
