Driver side climate control seat stopped working?
2015 INFINITI QX60
65,000 MILES • 6 CYL • 4WD • AUTOMATIC
TIMLAW
  • 7 POSTS
Abruptly, the driver's side climate control seat in my vehicle listed above Hybrid stopped functioning. When turning the dial to cool or heat, the light doesn't turn on.
Checked the fuse and it looked fine, even swapped with the passenger seat fuse and no change.
I have seen answers about the light coming on and shutting off quickly suggesting a bad module, and the car has a service bulleting from Infiniti for replacing the module and harness, but before a $1,500.00 repair, I am wondering if there is a simpler answer.
Nov 21, 2022 at 3:21 PM
So, there are three fuses that run the system that need to be checked for power, fuse# 29 in the lower side of the dash fuse panel and fuses# 71 and #72 in the fuse panel in the left rear of the engine compartment. This guide will help, and I have included the fuse locations as well. If the fuses are good, there is a climate control seat relay that is on the right side of the dash I would swap out. I have included the climate-controlled seat wiring diagrams so you can see how the system works as well.
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem.
Nov 23, 2022 at 11:35 AM
TIMLAW
  • 7 POSTS
Hi Ken L,
Thanks for the reply. I tested all 3 of those fuses and confirmed that they are in good working order with resistance both in and out of the fuse boxes in the car.
Here is a video of the power being turned to cool and heat on both seats, with the light not turning on for the driver's side.
Is that relay that you are referring to one that requires removing the glove box to get to? Also does it control only the driver's side?
Thanks again.
Nov 25, 2022 at 1:35 PM
Yes, the relay controls both seats and you need to remove the glove box to service the relay.
Nov 26, 2022 at 11:29 AM
TIMLAW
  • 7 POSTS
Hi Ken,
I was finally able to get into the car and take the glove box out to test a new relay. The new one did not change the behavior of the climate control seats.
Next I tries opening up the center console to see if I could switch the wiring on the switches for the drivers and passengers sides, but the plugs were different so I wasn't able to try that.
Dec 4, 2022 at 1:20 PM
Okay, this leaves the system ground, the controller or the heating element in the seat is shorted out. Please unplug the seat to see if the lights come back on to the switch. Please let me know.
Dec 6, 2022 at 11:28 AM
TIMLAW
  • 7 POSTS
Sounds good. I'll try unplugging the seat tonight and let you know.
As background, a couple months ago, the main ground on the engine harness had been chewed through by a rodent and the whole wiring harness was replaced. The seat climate control did work for a few weeks after, but then stopped.
Dec 6, 2022 at 11:33 AM
Yep, those little buggers can cause all kinds of problems. There is a ground on the right side of the dash they may have chewed through as well so I would check that as well.
Dec 7, 2022 at 9:51 AM
TIMLAW
  • 7 POSTS
I unplugged the seat and verified the switch for the seat climate control behavior didn’t change. Still didn’t power on at all, the light on the switch stayed off.
Dec 10, 2022 at 4:55 PM
Okay, if the grounds are good and the climate control module of the seats is getting power this leaves the controller itself as being bad. Here is the location so you can change it out. Check out the images (below). Please let us know what happens.
Dec 12, 2022 at 12:27 PM
TIMLAW
  • 7 POSTS
Took a while to get time to get the module and pull the seat, but this looks like it is likely the issue, there is definitely damage to the module.
Unfortunately, the wiring harness is damaged as well, and looks like it needs to be spliced in, so I am ordering a new harness. Hopefully, this will solve the issue.
Thanks again
Dec 26, 2022 at 2:08 PM
Yep, you have found the problem. I would get the new pigtail and splice it in this should fix the problem. It must have been a bad connection which caused the circuit to overheat, producing the damage you see here. Nice work.
Dec 27, 2022 at 12:05 PM
TIMLAW
  • 7 POSTS
Finally got a break in the weather to splice in the new wiring harness and we now have a functional climate control seat.
Jan 7, 2023 at 11:59 AM
Nice work! Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Jan 8, 2023 at 5:48 PM
  • 0 POST
Good morning, I am new to this feed but I just bought a 2014 Infiniti qx60 hybrid, and it is having the same problem, I have seen multiple modules I am curious if you have some better pics of the module so that I get the right one. I seen quite a few on Ebay etc. that say they are compatible with my 2014 but bolt holes look different, so I was trying to see if you had some photos of the right one to get.
Mar 4, 2026 at 4:45 AM
Welcome to the site, here is an image of the user replacing the module, your should look like this as well. Let me know what happens please. Ken
Mar 4, 2026 at 7:37 AM
