Most commonly, that is an indication of a bad/weak ground. Because of the model year, I don't have a clear wiring schematic, but if I recall, the brake light and turn signal use the same element in the rear bulbs. Either it should be an 1157 or a 2057 bulb. One element works for the parking light and the other for the brakes and the signal.
Do the turn signals seem to work properly? Also, what I need you to do is this. With everything off, we need to determine which wire provides a ground path for the brake lights. So, disconnect the connector and check each wire for continuity to ground. We need to confirm that there is ground. Or, you can use a test light and have a helper press the brake pedal while you check which wire supplies power. That will narrow it down for you.
Once you determine which wire is ground, just as a test, place a jumper wire between it and a known good ground to see if that changes how the light works.
Let me know. Also, check inside the light socket to make sure there is no damage or corrosion.
Jul 27, 2021 at 8:48 PM
