Driver side blowing cool air on heat and warm on A/C
2002 CHEVROLET TRAILBLAZER
67,284 MILES • 4WD • AUTOMATIC
20GRANDWOOD
Everything was working fine then I noticed while trying to change the temperature of the air flow it never changed temperatures, but the passenger side works fine.
Sep 20, 2019 at 7:06 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It sounds like you may be having a problem with the blend door actuator. Here is a tutorial showing what is involved for its replacement:
Before I send you more detailed step-by-step instructions I will need to know from you if it is an automatic or manual control system.Hope this helps and thanks for using 2CarPros.
Danny-
Sep 20, 2019 at 4:16 PM
