Have Dual climate control. Currently blowing hot air on drivers side regardless of temperature setting, but passenger side responds to all controls as normal. I have located the passenger side blend door actuator that responds to temperature settings just fine and also the recirculate actuator. Both are behind the glove box and both work fine. I have also located the actuator that controls air flow from defrost through chest-level to foot level, all works fine and that is behind the panel and plate under the steering wheel (left hand drive). What I cannot find is the blend door actuator that controls air flow on the drivers side based on temperature setting. Can you help? (300 L model)
May 10, 2018 at 1:54 PM
