Power driver's seat not working?
2012 MERCEDES BENZ E350
103,000 MILES • V6 • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,008 POSTS
Just noticed that the driver seat does not move up down back or front, even the power headrest doesn't move. This is a convertible 2 door. But, when i lift the lever on the side of the seat which moves the seat forward on its own to let passengers get in the back it moves. When i released it, it went back to where it was. Scanned it but no codes. Activated it via the scanner in all positions and everything moves. Does this mean the fuse is good? If not necessarily do you know where it's located? The seat switch is located on the driver's door. Trying to eliminate whether it's the switch or something else.
May 24, 2025 at 1:54 PM
It seems like the position switch for the back of the seat is not working correctly or the seat controller when bad.
May 25, 2025 at 12:23 PM
BHAMDOC1973
  • 2,008 POSTS
What is a position switch?
May 25, 2025 at 12:46 PM
BHAMDOC1973
  • 2,008 POSTS
Removed door panel and wire to the module was loose. All good
Jun 2, 2025 at 10:04 AM
Good find! Glad you got is fixed.
Jun 2, 2025 at 11:38 AM
