Hi Ken, took a bit of trying but this is the easiest way for me to explain it but it worked this way not like owners manual said. Hope I made it English enough to understand. Thanks -Jerry
Setting Seat Memory
2014 Cadillac
With the car running- In the settings menu go to vehicle then go to comfort and convenience, then set your seat, steering wheel, and mirrors the way you want them for driving. Then on the door push the set button and number one button at the same time until you hear a beep then let up on the buttons. Then go to auto memory recall and make sure (at ignition on) is selected. Then for exiting car set your seat and steering wheel in the position you want them to be in then push on the door the set button and easy exit button at the same time until you hear a beep then let up on buttons. Then in vehicle settings go to comfort and convenience go to easy exit options and select on. For car to automatically lock when leaving the car. In settings go to vehicle then go to (remote lock, unlock, start)- then go to passive door lock and check (on)- then go to passive door unlock in menu and check driver door. (driver door) done.
Dec 14, 2016 at 11:58 AM
