Driver rear running light not working
2004 DODGE DURANGO
210,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
SB73
  • 8 POSTS
Every single one of my lights work except my driver's side rear running light, I put in a new connector panel on back thinking it may be the socket but no, I don’t know if it could be a fuse because everything, but one works, all new bulbs except the tiny little one. I didn’t see any problems with wires, there were trailer lights hooked up, but they were disconnected and just tied to the vehicle. I’m lost, I don’t know what it could be.
May 31, 2022 at 10:40 PM
There is a fuse #8 in the power distribution module that needs to be checked for power. To see if the fuse is good this guide will help you test the fuse and for power as well. Also included the fuse location in the diagrams below, plus I have included the wiring diagrams for the system so you can see how it works.
Jun 1, 2022 at 11:40 AM
SB73
  • 8 POSTS
I’m home in roughly two hours and will have an explanation. Thank you for pointing that out. I also went to use my multimeter at work today and it went down so I will not be able to do anything but pull and temp a proper fuse to get an answer.
Jun 1, 2022 at 5:18 PM
Sounds good, let me know.
Jun 2, 2022 at 9:17 AM
SB73
  • 8 POSTS
The diagram doesn’t match.
Jun 2, 2022 at 12:09 PM
SB73
  • 8 POSTS
The left box has a 10a fuse far right that has no continuity.
Jun 2, 2022 at 12:10 PM
Did you replace the fuse? What happened?
Jun 3, 2022 at 6:37 PM
SB73
  • 8 POSTS
The absolute unexpected, I had finished up changing plugs, coils, injectors, broken connections, new idle air sensor and new throttle sensor, started her up, sounded great, loud clink in the engine and now have a rattle. Checked my dipstick, bone dry. Have had no signs of a leak, there was a small trans leak but that was fixed. I did an oil change a week ago, filter and plug were good. Area around my plug was saturated but not dripping, filled with oil and put boards under, still no drip, but it was empty, so now my taillight does not matter as my engine is no good, it runs but it should not be run.
Jun 3, 2022 at 7:15 PM
I am sorry to hear that, let me know if you need help fixing the engine (start a new question) or when you need any further help with the light operation. We are here to help, please use 2CarPros anytime.
Jun 4, 2022 at 10:56 AM
