Driver power window
2011 FORD EDGE
155,000 MILES • V6 • AWD • AUTOMATIC
NAIF83
I have the door ajar sensor problem. So to fix it. I cut the wrong wire and ground it which caused a spark. Reconnected the wire. Now my driver power window will not work. Green purple wire.
Feb 9, 2017 at 12:12 PM
STEVE W.
  • 15,113 POSTS
Check fuse 32 (15A) in the body control module.
Feb 9, 2017 at 12:39 PM
JREIN71
I did almost exactly the same thing. I shorted the wrong wire to ground trying to fix the door ajar issue...which caused the driver side power window to stop working. I checked fuse #1 in the BCM and it was fine. Based on Steve W's suggestion, I checked fuse #32, and it was blown. I changed the fuse and the power window works again! As a side note, I did find the right green/violet stripe wire that goes to the driver door ajar sensor. There are two green wires with a stripe in the wire bundle behind the removable panel that runs along the floor by the driver door...as I recall the correct wire for the door ajar sensor is slightly thinner.
Feb 22, 2017 at 6:52 PM
STEVE W.
  • 15,113 POSTS
Thank you for using 2CarPros.com.
Tell your friends, family and anyone you like about us and please return with any auto related questions, we're here to help.
Feb 22, 2017 at 8:06 PM
SALMAN SABEEH
Hi friends,
I have Ford Edge Limited 2013, also almost exactly the same thing. I shorted the wrong wire to ground trying to fix the door ajar issue.
But I checked fuse 32 it was fine, so only window drive not work to now, what I do, please?
May 17, 2020 at 8:49 PM
There is a circuit breaker #48 and an accessory delay relay that need to be checked. here is a guide and the location of the breaker and the relay with the window wiring diagrams so you can see how the system works:
and
May 18, 2020 at 11:21 AM
