Toyota Product ID: 69040-04010 (Lock Assembly –driver side)
VIN: 4TASN92N8YZ598848
This is a Pre-runner (SR-5 body trim) 3.4L V-6, 4 speed automatic.
Dear 2CarPros,
I have removed the defective lock actuator and installed the new lock actuator assembly and reconnected both the mechanical and electrical connections. Mechanical, it works great. However, electrically it is does not work. The driver’s armrest control switch operates both windows and the passenger’s door lock only. The driver’s power lock is not working, with power connected. I have checked all fuses and other electrical connections. I have not been able to isolate this problem. And answer why is the power lock actuator assembly is not functioning electrically? I am reaching out to check with you for any suggestions. Where should I look next? Thank you for your time and attention concerning this matter. Any help would be much appreciated. Thank you and have a great day.
Dear 2CarPros,
Dec 8, 2016 at 12:46 PM
