Hi, I have the car listed above that is hard starting, seems to idle okay and at idle, the fuel numbers (live data from autel MaxiSys906) are all in spec. (Code P0087 is present) However with acceleration, the car misfires, lacks power, and the high pressure fuel numbers drop to 150-300psi. The low side numbers are around 100-104. I would like to properly diagnose the car before I put a $200.00 high pressure fuel pump in it. Can you give me a test procedure to isolate the sensors and pumps to make sure I change the right part?
Feb 7, 2021 at 7:02 AM
