Car will crank up and drive beautifully until in every gear at around 4,000 RPMs the car will buck and jerk back and forth until the gas is let go or you switch gears as long as you drive slow in each gear it drives fine only under heavy acceleration and pushing rpms past 4 thousand RPMs will it happen and if you keep on the car just cuts completely off.
Dec 11, 2024 at 3:50 AM
