Drive shaft issue
2006 PEUGEOT 307
50,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
WOODZY1212
I have just replaced the clutch on the car. i have fitted everything back together but when putting the car in gear only the passenger drive shaft is engaged. I have taken the other side back out and reseated twice now.
if i put the car in gear but not turn engine on and spin either wheel both wheels turn as they should and both drive shafts are fully engaged, as soon as i actually start the car and select a gear it goes straight back to only the passenger side working,
if i get under the car whilst in first gear and engine running i can freely spin the drive shaft that comes directly out of the gearbox to the drivers wheel in either direction there is no engagement or resistance.
Oct 1, 2019 at 5:42 AM
It sounds like the retainer clip on the end of the CV axle is missing? Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Oct 3, 2019 at 1:26 PM
