As far as the issue, the entire driveshaft shouldn't need to be replaced. You can replace the universal joint which will be much less expensive.
However, I need to confirm something. When you say driveshaft, are you referring to the propeller shaft that connects the trans to the read differential or an axle assembly? I ask because the axles can often be referred to as a drive shaft.
Take a look at this link. It explains what one is and how to check one.
https://www.2carpros.com/articles/how-u-joints-work
Nov 10, 2022 at 9:09 PM
