Unfortunately the only way to clear that monitor without just letting it clear over time is to perform the drive cycle laid out. Just make sure you are seeing the special tip of if the engine is shut off to start over. Did you let the vehicle sit for at least 8 hours before trying this?
Also, step 6 says to drive the vehicle for about 15 minutes. Then step 7 says to keep steady throttle 50-70 mph without moving the accelerator for a minute. This is after the 15 minute drive.
Each step is separate so do one as it states then move onto the next. If this does not cause it to pass then you will need to try it the next day.
This is the hardest one to get to pass so just make sure you are doing it exactly as it says or it won't pass.
Let me know what happens.
Sep 7, 2020 at 7:13 PM
