Drive belt replacement?
2002 CHEVROLET SILVERADO
120,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
RDEEDS51
Serpentine belt broke and is missing. I need to know what belt to purchase. My truck uses 2 belts, the A/C is separate. I purchased a 93 inch belt. It is too long.
The VIN is 2GCEK19TX21401601
If this will help.
Sep 17, 2025 at 4:42 PM
STEVE W.
  • 15,113 POSTS
There are 2 possible belts for that vehicle. The difference is if you have the heavy duty alternator option. The base 105 amp alternator takes a 92.25" # 6K923 while the 130 amp unit uses the 93.75" inch # 6K930 (I suspect this is the one you have) The belt routing is still the same but the larger alternator has a slightly larger pulley on it.
Sep 17, 2025 at 11:53 PM
