How to install the drive belt?
2005 KIA SPORTAGE
106,000 MILES • 2.7L • V6 • 2WD • AUTOMATIC
ROB2467
having problems putting drive belt on.
Jul 11, 2021 at 9:16 PM
Are you sure the belt is the correct length? Also, make sure you have it routed properly.
If you look below, it provides the directions for adjustment. Take a look through it. It may help you get it installed. Also, here is a link explaining in general how one is replaced:
https://www.2carpros.com/articles/replace-serpentine-belt
Let me know if this helps. If it doesn't let me know exactly what is happening to prevent you from getting it into place.
See pic below.
Jul 11, 2021 at 9:30 PM
ROB2467
I have the belt on but it doesn't fit on all the pulleys and it's the same as the old one. it seems like tensioner is not moving far enough.
Jul 11, 2021 at 9:45 PM
ROB2467
Do I have to loosen the alternator?
Jul 11, 2021 at 9:47 PM
STEVE W.
  • 15,113 POSTS
With a spring tensioner you don't need to move anything if it's the correct belt. Was anything other than the belt changed?
Jul 12, 2021 at 7:43 AM
