I have a 1999 Ford Ranger, 4 Cylinder, 2.5 liter. I was having trouble with it on startup and sputtering until I got going. I found that if I disconnected the tube from the EGR valve things ran much better. I found the EGR valve was leaking so I replaced it but the problem still exists. I am pretty confident that I tested the EGR solenoid thoroughly and it is ok. I started looking at the DPFE sensor and have a question about the voltage. According to what I read, the bottom wire is the reference voltage and it is 5v. The middle pin is ground and I verified that it is good. The top pin should be the signal wire and should be about 1 volt until the pressure changes and it should rise along with the pressure. However, the signal wire has a constant 5v. I assumed this meant the DPFE sensor was bad but when I removed the wiring connector from the DPFE sensor, I found that pin 1 still had a constant 5v. I checked and there is no continuity between the signal pin1 and the 5v reference pin (trying to rule out a short in the connector). Now I am wondering if this constant 5 volt from the PCM is normal or is the PCM supplying 5v that it shouldn't. Any help would be appreciated.
Dec 19, 2015 at 3:36 PM
