I believe it is the original trans. I bought it used and there weren't any records. The fluid was dirty and maybe a 1/3 of a quart low.
I changed the fluid and filter. And put in some lucas stop slip hesitantly because I knew I might have to do it again to replace solinoid(s). It didn't solve the problem.
Is it possible that the speed sensor on the rear rear wheels could be causing this and my ABS light to come on?
My scanner doesn't have Can Bus so I tried having some of the auto parts stores scan it and they didn't detect and codes either.
So I suppose it's probably a solenoid problem.
Some answers say it might be the 2-3 or a pressure solenoid. I thought I saw that solenoids weren't that expensive so maybe I should just replace both?
Sorry if I'm not really quick about all this. I have a ruptured disc and sciatica that is slowing me down majorly. I'll wait for your next thoughts before I start throwing parts at it.
Do the trans repair stores have a special scanner that wouldn't cost alot? Or would it be cheaper to try and buy a scanner with Can Bus reader? I thought I heard someone say that there were some on Amazon for $35. I haven't looked but it sounds good to be true. When I bought my scanner I'm pretty sure a Can Bus scanner was about $500.
Thanks to everyone that replied.
May 17, 2023 at 9:33 AM
