Door will not close?
2006 SEAT IBIZA
130,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
SULA
Passenger door won't close, just swings to, but does not latch.
Feb 5, 2021 at 9:45 AM
There is a chance that the latch just got flipped so try and open the inside door handle then close it. Meaning just pull the handle on the inside of the door like you were opening the door and that will open the latch.
If that does not work then here is a guide that will help with this:
https://www.2carpros.com/articles/car-door-hood-or-trunk-will-not-close
If none of this works then I suspect we will need to remove the latch and replace it.
We don't have a manual on your vehicle that shows how to do this but here is another guide that will help get the door panel off and that will get you access to it:
https://www.2carpros.com/articles/door-panel-removal
Let's run through this material and go from there. Thanks
Feb 6, 2021 at 2:24 PM
SULA
Brilliant! Sorted. Thank you so much.
Feb 7, 2021 at 1:20 AM
Awesome. Thanks for the update that this worked. That will surely help others. Please come back and thanks for using 2CarPros.
Feb 7, 2021 at 3:19 PM
