Door trouble
2008 TOYOTA SIENNA
140,000 MILES • 4 CYL • FWD • AUTOMATIC
NICHOLSON4
  • 8 POSTS
The rear passenger door will not open, neither the power door nor inside or outside latches will work. Is there any easy way to get it open without forcing it?
Aug 4, 2016 at 6:05 PM
HMAC300
  • 48,601 POSTS
have a mechanic scan for codes his scanner may be able to open door manually. otherwise you will have to remove door panel from inside car and see what if anything like a clip is broken/fallen off.
Aug 5, 2016 at 7:09 AM
