door panel
1993 JAGUAR XJ6
178,000 MILES
BRUCE 2
i want to get the door panel off but can't open the door to take it off and is there a way that I should take the panel off if iiI can get the door open. I don't want to damage the door panel . where would the screws be to undo the latch
May 27, 2013 at 5:26 PM
HMAC300
  • 48,601 POSTS
the pic i'm sending is the only one I can find for door. but check armrest for screws and once that is off there should be clips allaround panel to remove. it won't be easy but can be done.there may be screws at top as well. once panel is loose lift upwardsto remove the latch may not be broken but there are either plastic clips or metal ones that break that hold rods that go to latch if yousee it broken just pull on rod and door should open.
May 28, 2013 at 6:49 AM
