Hello good Samaritans,
Two issues suddenly manifested, the automated door locks only open when switch is pressed cannot close when switch is pressed on the main driver side switch controls nor on the individual door switches.
The windows do not respond to switch controls except for passenger window and driver rear windows on opposite sides are w working in alternate Cris crossing while other sides have no power to door switches.
The sudden onset happened when I hard wire the dash cam to battery positive and fused dome lights 12-amp fuse in main fuse box with a mini piggyback fuse holding the dome fuse and a 5-amp fuse.
did I create a short by looping positive side to positive? The cam dash camera is grounded to left panel body ground.
I checked all fuses, no blown fuses in main fuse distribution box and under dash fuse box. Use the simple handy dandy test light to ground.
I also heard a swishing sound coming from the injectors diagnostic toll said in "pending" code p0301 miss fire on cylinder 1 but in dtc. It maybe and intermittent issue which was suddenly apparent for the first time.
It seems ok by sound check; Now I had replaced the injectors 5 months ago I used di electric grease on the O rings to insert injectors to fuel rail.
I check injector fuse 15amp it is ok lights up fine and gentle tapped and rocked the relays nothing happened.
Observations: cam dash camera is unrelated and fuel injector is a separate issue.
In Spain you cannot be a doctor until you chose a practical trade like automotive, carpentry, pluming reason being human body is a 4-dimensional organic biological machine with a formless body called the soul it cannot be seen yet its intelligent and all-knowing a doctor is no different from a plumber auto-mechanic and a carpenter. The only difference is that a doctor can gravely hurt a human being, am glad I chose not to be a doctor.
In touching cars and pondering their science and wonderment, I have discovered that the machine has its own consciousness personality and loves you when you care for it. We know or think objects like machine cannot feel they are not alive, yet my discoveries tell me they start out as an idea when they take form as the car, they are infused with the elements of the earth, so they too take on a live vibration.
Master mechanics have you experience this phenomenon too?
Respectfully,
Alphasentory Galaxy
Respectfully,
Alphasentory Galaxy
Dec 3, 2021 at 1:02 AM
