Door locks
2010 NISSAN SENTRA
60,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
DTDODD
  • 24 POSTS
The driver side door lock quit work with the key fob but works with the key. Now all of a sudden the driver side rear door lock is doing the same thing. Could this be the actuators or is there a fuse that controls these?
I have never had this problem.
Apr 17, 2017 at 4:38 AM
HMAC300
  • 48,601 POSTS
check battery in key fob and see if fob works auto parts can check it. then have a mechanic scan for codes.
Apr 17, 2017 at 7:49 AM
DTDODD
  • 24 POSTS
only issue if it were the battery in the FOB all locks would not work not just one or two. No codes
May 8, 2017 at 10:43 AM
HMAC300
  • 48,601 POSTS
for the no codes was it checked by a mechanic or auto parts scanner as those won't pic up any codes like that they only pic up engine/trans codes. it may very well be the actuators or a short in system like wires broken which will have to be checked to see if they get power or not. it cold also be a clip broken as to why they aren't working.
May 8, 2017 at 12:06 PM
DTDODD
  • 24 POSTS
Broken clip. What clip would that be?
Aug 5, 2017 at 5:03 PM
I will be taking over this thread, does the car have an intelligent key?
Best, Ken
Aug 7, 2017 at 1:26 PM
DTDODD
  • 24 POSTS
Intelligent key? It has a key fob for remote entry and arming alarm
Aug 9, 2017 at 5:08 AM
The best way to check this problem is to use a test light which you can then tell if the actuators are getting a power signal.
Here are some guides and a wiring diagram so you can run some easy tests to confirm the actuator or BCM failure.
and
https://www.2carpros.com/articles/door-panel-removal
Aug 9, 2017 at 11:15 AM
