Door lock fuse location
2003 NISSAN ALMERA
300 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
WISEMAN28
  • 5 POSTS
I have problem with my car listed above. I'm no more lock my doors and boot with the doors locked button in the driver door. I think is the fuse but I don't know where is that fuse located. clock in the cluster doesn't display any more. help please
May 2, 2020 at 5:13 AM
First, this vehicle isn't offered in the US, so I have no manuals specific to it. However, I looked online and found fuse box info. Now, for some reason, they do not list a door lock fuse. However, often times they are in conjunction with the windows power supply. I attached a pic. It is the under hood fuse box and I highlighted the window fuse.
Let me know if that helps.
May 2, 2020 at 6:11 PM
WISEMAN28
  • 5 POSTS
Okay, thanks. I will check and let you know.
May 2, 2020 at 10:04 PM
Sounds like a plan. I just hope it is accurate. Let me know what you find.
May 2, 2020 at 10:11 PM
WISEMAN28
  • 5 POSTS
I found lock doors fuse but if I put on doors locks keep on locking and unlocking continuously until I take the fuse out.
May 5, 2020 at 3:52 AM
Are you able to check for a good ground? I feel bad I have no schematics to look at to guide you. However, that would be the next thing I would check as well as the switch itself.
May 5, 2020 at 9:06 PM
WISEMAN28
  • 5 POSTS
Yes I can.
May 5, 2020 at 10:28 PM
Sounds good. Let me know what you find. Hopefully it will be something simple.
May 6, 2020 at 9:23 PM
