My 2001 GMC Sonoma has had the door pins replaced by my dealer while still under the warranty. Since then I had to have my mechanic replace them at least twice. The last time he did so he said the hinges to the door are peeling off. Some kind of adhesive was used to put door hinges on a vehicle?!?! Makes me wonder about new cars even today. Anyways I am tired of the issues with this door to point I wish I could afford a new truck. This truck is a great vehicle and is very dependable. A body shop cant fix it for like 1200 bucks. They agreed with my mechanic that the door hinges need taken off and welded or bolted back on but the problem is the door where it latches shut all the parts are messed up and I come to find there is a plastic gear in there. Why would GM put plastic parts and glue hinges on a truck door? Is there any chance there could be a recall and GM might fix these things? Is there anyways this can be fixed with little cost? Also it has caused the door panel to get busted now twice. I hope someone can help. Thank you.
Jun 5, 2013 at 9:48 AM
