Rear left door removal instructions needed
2002 AUDI A4
170 MILES • 1.9L • MANUAL
JK3YZ
Need to know how to take off my rear left door on my Audi A4 estate 2002 plate.
Thanks
PS. not the door panel. The whole door. Fed up of seeing door panel everywhere just want to know how to remove the door.
Simple question. Simple answer. Thanks
Sep 27, 2019 at 9:30 AM
You just need to remove the door hinges but just the bolts that I highlighted. Let me know if you need more information. Thanks
Sep 27, 2019 at 4:21 PM
JK3YZ
Okay, that helps a little bit, but I kind of need a better picture than that. As I spent 9 hours yesterday trying to find what to do and what tools to use. so can you send me a better picture and highlight what needs to be done with what tools too?
Thank you
Sep 27, 2019 at 10:51 PM
How about you take a picture of your door hinges and I will highlight them on your pictures so you can see them? Take the pictures of only one hinge at a time so we will need two pictures. We need to be sure you can see the bolts that are on the body side of the hinge because those are the ones you need to remove.
As for the tools that you need. It is a ratchet and socket that fits the bolt that you need to remove.
Send the pictures and we can go from there. Thanks
Sep 28, 2019 at 1:01 PM
