done a vats bypass,,,,after rebuilding steering column,, engine cranks no start,,,,
1990 CHEVROLET CORVETTE
V8 • 2WD • MANUAL
COOL MAN
no fuel to injectors 42# pressure at fuel rail,,,,,code 46,,,,got weak spark at plugs,,,,service engine soon light stays on,,,,spray starting fluid briefly cranks
Oct 28, 2015 at 7:29 PM
HMAC300
  • 48,601 POSTS
whatever you did you screwed up your pass key is why it won't start that is code 46 if you replaced ignition switch have it coded to your system a pro will have to do this.
Oct 29, 2015 at 6:09 AM
