Put key in and try to start it does nothing
2004 PONTIAC GRAND AM
160,000 MILES • 2.4L • 6 CYL • AUTOMATIC
DONNAWOODLEE
  • 42 POSTS
All lights come on fuel pump comes on battery good. I replaced the ignition housing but not the switch the key actually goes in. But still nothing. Please help, desperate, Donna.
May 24, 2019 at 2:09 PM
SCGRANTURISMO
  • 4,897 POSTS
Is your security light blinking?
Thanks,
Alex
2CarPros
May 25, 2019 at 3:15 AM
DONNAWOODLEE
  • 42 POSTS
No, it's not blinking just stays on.
May 25, 2019 at 7:37 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Okay, when your security indicator is illuminated and your vehicle isn't starting that means that a fault has been detected and the system is in learn mode. I have included your vehicle's system operation and how to reprogram it in the diagrams down below. Please go through these guides and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
May 25, 2019 at 11:15 AM
DONNAWOODLEE
  • 42 POSTS
Okay, I'm not fully understanding all of this. Am I using the key I already have or buying a new ignition switch with keys and installing?
May 25, 2019 at 3:57 PM
DONNAWOODLEE
  • 42 POSTS
And I don't have all those fancy tools and diagnostic readers to do all of that.
May 25, 2019 at 4:03 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again, read the section that I highlighted for you in yellow. This is what your vehicle is doing. It refers you to "Programming Theft Deterrent System Components", so if you continue down 2 more diagrams, it describes step by step instructions on how to fix your vehicle. It will require the use of a Tech 2 Scan Tool. I believe you can pick one up on Ebay for around $150.00 to $325.00.
Thanks,
Alex
2CarPros
Okay, did you
May 25, 2019 at 4:48 PM
DONNAWOODLEE
  • 42 POSTS
I don't have that kind of money for a scan tool though.
May 25, 2019 at 4:57 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Usually the only place to get your key, or in this case, the new component that you installed, programmed to match up with the PCM is either the dealership or at a locksmith's. This is done intentionally to keep people from going around with a bunch of blank keys and programming them so that they can steal cars. This is an anti theft system after all. Please let us know what you decide to do.
Thanks,
Alex
2CarPros
May 25, 2019 at 9:51 PM
DONNAWOODLEE
  • 42 POSTS
From what I understand I can buy the new switch and it comes with key and I can reset the anti theft to work with that key.So what I'm needing to know is "could this be the part I'm needing to replace and will this key be able to be reset!
May 26, 2019 at 1:13 PM
DONNAWOODLEE
  • 42 POSTS
I'm really just needing to know what causes this to happen ,my car to do nothing when I turn key over when all lights come on and it's not the battery and not the fuel pump and the security light does not flash just stays on??
May 26, 2019 at 1:16 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
As I have previously sent you the description of the Vehicle Theft Deterrent (VTD) system operation for your vehicle, the components of the VTD, and directions on how and why the components are programmed with each other, I would refer you back to them. I am sorry, there is no magic bullet that I can offer you to fix this problem. I really wish there was, I would love to tell you if there was, but there isn't. Sorry.
Thanks,
Alex
2CarPros
May 26, 2019 at 1:26 PM
DONNAWOODLEE
  • 42 POSTS
Okay, well what I'm saying is, I don't understand all that stuff that you sent me. I'm a female and not a mechanic so if you could explain to me what part that I'm needing it would really help me out a lot.
May 26, 2019 at 1:42 PM
DONNAWOODLEE
  • 42 POSTS
Okay, when I put new part on everything remained the same as with old part so I took off and put old back on because there was no change at all so therefore I don't think that was the issue. so I'm needing to know what else nay be the problem? I'm sending picture of part I replaced and removed and put old one back on.
May 26, 2019 at 2:27 PM
I would like to jump in here. I think we are going down the wrong trail because the light is not flashing the system is not engaged. It sounds like the starter has gone out. To confirm here is a guided that will show you how to check for power at the solenoid:
https://www.2carpros.com/articles/starter-not-working-repair
May 29, 2019 at 7:26 PM
DONNAWOODLEE
  • 42 POSTS
Okay my friend, ran the starter to a switch so now when I turn key over and hit starter switch at same time it starts but immediately shut off.
May 29, 2019 at 8:00 PM
When the engine stalls does the security light flash?
May 30, 2019 at 11:51 AM
DONNAWOODLEE
  • 42 POSTS
No.
May 30, 2019 at 12:31 PM
DONNAWOODLEE
  • 42 POSTS
So if my starter is wired to a switch and now my car starts but shuts off. could my starter be the problem or does this mean starter is good? Please help!
May 30, 2019 at 10:06 PM
Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
May 31, 2019 at 10:38 AM
The starter is good, when the engine stalls can you use starting fluid get make it run again? Also can you hear the fuel pump running in the tank?
Jun 1, 2019 at 1:04 PM
