starting inconsistently There is no fuel smell
2001 FORD ESCAPE
80,000 MILES • 3.0L • 6 CYL • 4WD
RALPHW
My vehicle has started not starting consistently. There is no fuel smell. The fuel pump sounds when ignition is turned on, and provides pressure to the place where a gauge would be connected (screw driver at this point will cause fuel to squirt).
The strange symptom is that if starter fluid is sprayed in the intake when the engine is cranked, the car will start and works for a day or more. If the car is warmed up well (driven on the freeway) and left to sit for hours it seems the problem reoccurs more often.
I have just over 80,000 miles on the car. The fuel filter was changed by the dealer a year ago.
Jun 19, 2016 at 9:35 AM
Hey RALPH,
Is sounds like you have a crankshaft angle sensor that is bad but to be sure please follow this guide and do some testing
Let me know what you find
Best, Ken
Jun 20, 2016 at 7:12 PM
RALPHW
Ken, I sent you a reply but it did not show up under replies so I will try again. You were correct. We checked the resistance of the old crankshaft sensor and it was open. A new one had approximately 30k ohms. Thanks.
Ralph
Jun 22, 2016 at 9:24 PM
That's good to hear we could help you fix the problem, please use 2CarPros anytime, we are here to help
Jun 23, 2016 at 9:35 AM
