Hello again,
Okay, lets make sure that the signal is getting to the PCM. This is going to require you to use a multi-meter. If you are not familiar with how to use one I have included a link below.
Okay, can you please double check the connector for the CKP sensor. Make sure that it not damaged, clean, and making good connections to the pins when connected. Next we are going to have check to make sure that the signal is getting to the PCM. A couple of things that will make this a lot easier to do is a couple of safety pins, and a couple of long jumper wires with alligator clips attached to both ends.
Pierce both the wires coming from the CKP connector a couple of inches from the connector with a safety pin. I pin, one wire. Clip a jumper wire to each of the safety pins securely. Attach the other ends of the jumper wires to a lead from the multi-meter. red test lead should hook up to brown wire, black to white wire. Turn your multi-meter to AC Voltage. Have an assistant crank the vehicle. Watch the multi-meter. You should get a reading from 7 volts - 14 volts.
I have included some information for you in the diagrams below as well. Please get back to us with what you find out please.
Feb 1, 2021 at 11:36 AM
(Merged)
