Does my car have an A/C bypass belt
2007 SATURN AURA
208,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
TRUTHSEEKER96
My power steering pump and serpentine belt went out. I had my power steering pump replaced so the leakage has stopped. However, the serpentine belt broke and I think I need to have my A/C compressor replaced.
Does my car make and model have a bypass belt? Does this sound like the A/C compressor needs to be replaced?
Apr 28, 2019 at 1:53 PM
Welcome to 2CarPros.
I have to ask why you question the compressor? Is it locked up? As far as a bypass belt, nothing is made. However, if the compressor is locked, what I suggest is an AC bypass pulley. The compressor is removed and the bypass pulley replaces it. Then the original type belt.
Let me know if this helps. By the way, these pulleys are not expensive.
Apr 28, 2019 at 7:40 PM
TRUTHSEEKER96
My family member was working on the car, and thought that A/C compressor might need to be replaced.
Apr 28, 2019 at 8:38 PM
Were there symptoms that made him say that? Also, does the AC work? Does the belt squeal when the AC is turned on?
Apr 28, 2019 at 8:53 PM
ILLMAKE39
I guess this is a super old post, but I have a 09 Saturn Aura 3.6 and my A/C compressor is seized up going to cost way more than I can afford to replace it. I saw someone had posted that they do make a bypass pulley, but I've not been able to find one if they do. Is there a smaller belt i can try and bypass it with if not?
Mar 31, 2022 at 6:58 AM
