1999 Dodge Van car stereo
1999 DODGE VAN
161,000 MILES • 6 CYL • FWD • AUTOMATIC
PETERSON2001
Can you conect a amplifier to a stock radio
May 29, 2009 at 2:58 PM
MOTORMANIA15
  • 15 POSTS
you can hook up an external amplifier to a stock radio, but you would need to get a signal converter, but there is a downside to it, you can only use up to a 500 watt amp, if you go any higher, you will burn out the preamp in the head unit. So if I were you I would put in an aftermarket radio so you can run a higher power amp later on this is a signal converter
https://www.2carpros.com/forum/automotive_pictures/374034_line_out_converter_1.jpg
Jul 3, 2009 at 7:08 PM
