1994 Dodge Van overheating after replacing thermostat
1994 DODGE VAN
10,000 MILES • V8 • 2WD • AUTOMATIC
MADAME E
I have a 1994 Dodge van D250, 3.9 l, v-6 with AC, that I have replaced the fan clutch, water pump, thermostat & hoses and still it continues to overheat? What else is there to replace? What am I missing?!
Dec 30, 2008 at 3:19 PM
MICHAELO 1949
  • 4 POSTS
If the radiator is original I would be checking to see if you have good flow.Water should go in the inlet opening and out the outlet equally.If it trickles out the bottom chances are the unit is plugged up ,hence slower flow and less cooling capicity. The radiator is suspect at this point.
Jan 13, 2009 at 1:21 AM
