1990 Dodge Van Head Lights
1990 DODGE VAN
DMAYO56
Electrical problem
1990 Dodge Van V8 Two Wheel Drive Automatic
The head lights, tail lights, and dash lights do not work. I have checked the fuses and replaced the switch. My question is; is there a relay or fusable link in line to the switch and where is it located?
Oct 27, 2009 at 11:19 AM
JDL
  • 16,098 POSTS
Welcome to the forum, I looked at info for a B150 van? Did you use a testlite and check for voltage and ground at the headlamp? Voltage to the headlamp switch is hot all the time, red wire with white tracer, use a testlite on that circuit. From the headlamp switch to dimmer, lite green wire. From the dimmer to headlamp, low beam, violet wire with white tracer. Ground wire is black.
Oct 27, 2009 at 11:43 AM
DMAYO56
I will do that,
Thank you,Dale
Oct 27, 2009 at 12:03 PM
