1974 Dodge Van
1974 DODGE VAN
STORM92CREED
Engine Mechanical problem
1974 Dodge Van V8 Two Wheel Drive Automatic
Will heads from a 440 fit on a 360?
Feb 12, 2010 at 10:24 AM
CARADIODOC
  • 34,306 POSTS
Nope. Two totally different animals. the 360 is a small block and is common to the old 273, 318, and 340. Besides the pistons, the only difference with the 360 is a crankshaft has larger diameter journals.
340s had high flow heads. The '68 - 71 340 heads are very desirable and valuable because they had bigger valves. Your 360 has the same heads as far as the runners are concerned, and the seats can be ground out and the larger valves installed from the early 340s. At that point, you will have a very valuable set of heads.
Even the highly sought after 340 can be easily matched by the more common 360 by modifying the heads. I have one sitting in a '73 Challenger behind my house right now.
caradiodoc
Feb 27, 2010 at 11:11 AM
